开启休眠后手机连接蓝牙很慢才能连接成功获取完所有服务
attribute((section("ram_code"))) void user_entry_after_sleep_imp(void)
pmu_set_pin_to_CPU(GPIO_PORT_A, (1<<GPIO_BIT_0));system_set_port_pull(1 << LOG_UART_RX_PORT_SEL, GPIO_PULL_UP, true); system_set_port_mux(LOG_UART_RX_PORT_SEL/8, LOG_UART_RX_PORT_SEL%8, 4); system_set_port_mux(LOG_UART_TX_PORT_SEL/8, LOG_UART_TX_PORT_SEL%8, 4); //system_set_port_mux(GPIO_PORT_A, GPIO_BIT_0, PORTA0_FUNC_UART0_RXD); //system_set_port_mux(GPIO_PORT_A, GPIO_BIT_1, PORTA1_FUNC_UART0_TXD); uart_init(UART0, 1152); fr_uart_enableIrq(UART0, Uart_irq_erbfi); /* RC calibration start. Ensure the accuracy of sleep wake time */ pmu_calibration_start(PMU_CALI_SEL_RCLFOSC, LP_RC_CALIB_CNT); uart_putc_noint_no_wait(UART0, 'w'); co_delay_100us(1); pmu_set_pin_to_CPU(GPIO_PORT_C, (1<<GPIO_BIT_2)); pmu_set_pin_to_CPU(GPIO_PORT_C, (1<<GPIO_BIT_3)); __SYSTEM_UART1_CLK_ENABLE(); system_set_port_pull(GPIO_PC2,GPIO_PULL_UP,true); /* set PC2 and PC3 for AT command interface */ system_set_port_mux(GPIO_PORT_C, GPIO_BIT_2, PORTA2_FUNC_UART1_RXD); system_set_port_mux(GPIO_PORT_C, GPIO_BIT_3, PORTA3_FUNC_UART1_TXD); Uart1_handle.UARTx = Uart1; Uart1_handle.Init.BaudRate = gAT_buff_env.uart_param.BaudRate; Uart1_handle.Init.DataLength = gAT_buff_env.uart_param.DataLength; Uart1_handle.Init.StopBits = gAT_buff_env.uart_param.StopBits; Uart1_handle.Init.Parity = gAT_buff_env.uart_param.Parity; Uart1_handle.Init.FIFO_Mode = UART_FIFO_ENABLE; uart_init_ex(&Uart1_handle); /*enable recv and line status interrupt*/ __UART_INT_LINE_STATUS_ENABLE(Uart1_handle.UARTx); __UART_INT_RX_ENABLE(Uart1_handle.UARTx); NVIC_EnableIRQ(UART1_IRQn); NVIC_SetPriority(UART1_IRQn, 1); NVIC_EnableIRQ(PMU_IRQn);
attribute((section("ram_code"))) void user_entry_before_sleep_imp(void)
pmu_calibration_stop();uart_putc_noint_no_wait(UART0, 's'); co_delay_100us(1); pmu_set_pin_to_PMU(GPIO_PORT_A, (1<<GPIO_BIT_0)); pmu_set_pin_dir(GPIO_PORT_A, (1<<GPIO_BIT_0), GPIO_DIR_IN); pmu_set_pin_pull(GPIO_PORT_A, (1<<GPIO_BIT_0),GPIO_PULL_DOWN);//GPIO_PULL_NONE pmu_set_pin_to_PMU(GPIO_PORT_C, (1<<GPIO_BIT_2)); pmu_set_pin_dir(GPIO_PORT_C, (1<<GPIO_BIT_2), GPIO_DIR_IN); pmu_set_pin_pull(GPIO_PORT_C, (1<<GPIO_BIT_2),GPIO_PULL_UP); pmu_set_pin_to_PMU(GPIO_PORT_C, (1<<GPIO_BIT_3)); pmu_set_pin_dir(GPIO_PORT_C, (1<<GPIO_BIT_3), GPIO_DIR_IN); pmu_set_pin_pull(GPIO_PORT_C, (1<<GPIO_BIT_3),GPIO_PULL_UP);
进入后退出休眠模式初始化了2个串口,这样的话休眠过程连接蓝牙就很慢,去掉打印ws就快不少,还可以怎么优化呢?
两个原因确认一下
1、你的广播间隔越小就越容易连接
2、频偏是否调了
