    2. dake
    D
    • 继续与 dake 聊天
    • 开始与 dake 的新会话
    dake
    @dake
    dake 关注
    dake 发布的帖子
    • bond_check_find_devs_idx: 是干什么用的?
      在主从连接过程中
      连接正常打印信息:
      link_created
      Stop advertising...
      SimplePheripheral p_event->type:3 addr_type:0
      bond_check_find_devs_idx:1
      SimplePheripheral p_event->type:1 GAP_EVT_SLAVE_CONNECT
      slave[0],connect. link_num:1
      SimplePheripheral p_event->type:11 GAP_EVT_ADV_END
      adv_end,status:0x00
      e_r
      SimplePheripheral p_event->type:25 GAP_SEC_EVT_SLAVE_ENCRYPT
      slave[0]_encrypted
      char2_recv:0x01,0x02,0x03,0x04,0x05,0x06,0x07,
      param_timer_func
      连接异常打印信息:
      link_created
      Stop advertising...
      addr_type:0
      bond_check_find_devs_idx:4
      adv_end,status:0x00
      e_r
      param_timer_func
      D
      dake
    • RE: FR8018主从连接异常
      这个bond_check_find_devs_idx是干嘛用的呢?
      D
      dake
    • RE: FR8018主从连接异常
      是同一份程序,从打印情况看是连接上了,但是就是不能通信,另外尝试无法通信从机刷主机程序,连接别的从机,也显示连接上了,但是这个主机无法通信正常从机,相当于这颗芯片的蓝牙仅能做从机被手机app连接表现正常。
      D
      dake
    • RE: FR8018主从连接异常
      没有用,还是上面那个效果,目前测试1主4从,仅有1从机表现异常,也尝试仅1主1从连接这个异常从机,仍无法收到主机消息,主机可以收到从机消息;使用手机app连接时,这四个从机表现均正常。
      D
      dake
    • FR8018主从连接异常
      FR8018主从连接异常
      两个从机程序相同,由主机扫描到后进行连接,一个连接正常可以通信,另一个异常
      正常从机打印:
      link_lost
      p_event->type:5 Link[0] disconnect,reason:0x08
      link_created
      Stop advertising...
      bond_check_find_devs_idx:0
      p_event->type:1 slave[0],connect. link_num:1
      p_event->type:11 adv_end,status:0x00
      e_r
      p_event->type:25 slave[0]_encrypted
      param_timer_func
      p_event->type:8 Link[0]param update,interval:12,latency:55,timeout:600
      char2_recv:0xAA,0x01,0x0A,0xB5,
      char2_recv:0xAA,0x01,0x09,0xB4,
      异常从机打印:
      link_lost
      link_created
      Stop advertising...
      e_r
      param_timer_func
      主机打印:
      freqchipfreqchipfreqchipfreqchipBLE Central
      Local BDADDR: 0x1A14383433CC
      Start scanning...
      evt_type:0x04,rssi:-39
      content:0x0E,0x09,0x43,0x46,0x53,0x49,0x2D,0x30,0x30,0x30,0x34,0x39,0x31,0x37,0x37,0x02,0x0A,0x00,
      start_con act[0]
      scan_end,status:0x00
      addr_type:0
      Start scanning...
      start_enc
      conn_end,reason:0x00
      bond_svc_info_flash_r
      connect one,conidx:0,client_id:73
      evt_type:0x04,rssi:-31
      content:0x0E,0x09,0x43,0x46,0x53,0x49,0x2D,0x30,0x30,0x30,0x34,0x32,0x33,0x36,0x36,0x02,0x0A,0x00,
      start_con act[0]
      svc:2,start_hdl:1,end_hdl:9
      svc:2,start_hdl:10,end_hdl:13
      addr_type:0
      bond_check_find_devs_idx:3
      Start scanning...
      start_enc
      connect one,conidx:1,client_id:73
      GATT_OP_PEER_SVC_REGISTERED
      0x10,0x00,0x14,0x00,
      0xBB,0x03,0xFF,0xBD,
      0x43,0x48,0x41,0x52,0x31,0x5F,0x56,0x41,0x4C,0x55,0x45,
      svc:2,start_hdl:14,end_hdl:31
      peer svc discovery done
      0x14,0x00,0x10,0x00,
      0x43,0x48,0x41,0x52,0x32,0x5F,0x56,0x41,0x4C,0x55,0x45,
      Link[1]param update,interval:12,latency:55,timeout:600
      索引0: conidx=0, client_id=73
      索引1: conidx=1, client_id=73
      0xBB,0x0A,0x00,0xC5,
      0xBB,0x09,0x00,0xC4,
      lvd.
      lvd.
      D
      dake
    • simple_periheral历程下载后微信小程序测试异常
      一直提示指令异常,丢包率100%是怎么回事呢?
      D
      dake
    • FR8018缺少driver_flash_ssp文件
      FR8018缺少driver_flash_ssp文件去哪里找?
      D
      dake
