    2. zxy
    • 继续与 zxy 聊天
    • 开始与 zxy 的新会话
    zxy
    @zxy
    zxy 关注
    zxy 发布的帖子
    • RE: 程序在heap_mem_alloc中死机
      @zxy ram空间应该不止这些啊
      发布在 FR303x
      zxy
      @zxy configTOTAL_HEAP_SIZE分配24k,configTOTAL_BTDM_HEAP_SIZE就最多只能分配11k了,否则就会报错
      发布在 FR303x
      zxy
    • 程序在heap_mem_alloc中死机
      请问程序在这个地方死机该修改什么值
      发布在 FR303x
      zxy
    • RE: 堆栈溢出
      @zr .\components\toolchain\armcc\fr101x_flash.sct: Error: L6388E: ScatterAssert expression ((ImageLength(PATCH_TABLE) + ImageLength(HOST_DATA) + ImageLength(ER_RW) + ImageLength(ER_RW_1)) <= 0xe380) failed on line 37 : (0xf378 <= 0xe380)
      这是报错信息,heap_size分了24 * 1024,btdm_size分了16 * 1024,小于ram空间的呀
      发布在 FR303x
      zxy
    • RE: 堆栈溢出
      我把这个值改大就可以了是吗
      发布在 FR303x
      zxy
    • RE: 串口中断异常,一直进中断
      @zr #include "user_driver_uart.h"
      #include "user_config.h"
      #define UART_DRIVER_TASK_MS (TASK_HIGH_SPEED_MS)
      static void usr_uart_get_data(UART_HandleTypeDef *huart);
      extern void uart_nvic_enable(UART_UserTypeDef_t handle);
      extern struct_UART_t
      uart_get_reg_addr(UART_UserTypeDef_t *handle);
      void usr_uart_IRQHandler(UART_UserTypeDef_t user_uart)
      switch (__UART_INT_GET_ID(user_uart->uart->UARTx))
      case INT_INDEX_TXE:
      Data transit end /
      if (user_uart->uart->u32_TxCount >= user_uart->uart->u32_TxSize)
      if (__UART_IS_TxFIFO_EMPTY(user_uart->uart->UARTx))
      GLOBAL_INT_DISABLE();
      __UART_INT_TXE_DISABLE(user_uart->uart->UARTx);
      GLOBAL_INT_RESTORE();
      user_uart->frame->frame_send_flag = true;
      else
      UART_FIFO_ENABLE /
      if (__UART_IS_FIFO_Enable(user_uart->uart))
      Until TxFIFO full /
      while (!__UART_IS_TxFIFO_FULL(user_uart->uart->UARTx))
      user_uart->uart->UARTx->DATA_DLL.DATA = user_uart->uart->p_TxData[user_uart->uart->u32_TxCount++];
      Data transit end */
      break;
      else
      break;
      case INT_INDEX_RX:
      case INT_INDEX_RX_TOUT:
      user_uart->frame->frame_recv_flag = true;
      user_uart->frame->frame_interval_cnt = 0;
      usr_uart_get_data(user_uart->uart);
      break;
      default:
      volatile REG_USR_t usr_status = user_uart->uart->UARTx->USR;
      break;
      void usr_uart_task(UART_UserTypeDef_t *user_uart)
      if (user_uart->frame->frame_recv_flag == true)
      user_uart->frame->frame_interval_cnt++;
      if (user_uart->frame->frame_interval_cnt >= (user_uart->frame->frame_interval_ms / UART_DRIVER_TASK_MS))
      user_uart->frame->frame_recv_flag = false;
      __UART_INT_RX_DISABLE(user_uart->uart->UARTx);
      if (user_uart->uart->RxCpltCallback != NULL)
      user_uart->uart->RxCpltCallback(user_uart->uart);
      user_uart->uart->u32_RxCount = 0;
      __UART_INT_RX_ENABLE(user_uart->uart->UARTx);
      if (user_uart->frame->frame_send_flag == true)
      if (user_uart->uart->TxCpltCallback != NULL)
      user_uart->uart->TxCpltCallback(user_uart->uart);
      user_uart->uart->b_TxBusy = false;
      user_uart->frame->frame_send_flag = false;
      void uart_driver_attr_init(UART_UserTypeDef_t *handle, uint32_t baudRate)
      handle->uart->UARTx = uart_get_reg_addr(handle);
      handle->uart->Init.BaudRate = baudRate;
      handle->uart->Init.DataLength = UART_DATA_LENGTH_8BIT;
      handle->uart->Init.StopBits = UART_STOPBITS_1;
      handle->uart->Init.Parity = UART_PARITY_NONE;
      handle->uart->Init.FIFO_Mode = UART_FIFO_ENABLE;
      handle->uart->TxCpltCallback = NULL;
      handle->uart->RxCpltCallback = NULL;
      uart_init(handle->uart);
      __UART_RxFIFO_THRESHOLD(handle->uart, 2);
      __UART_INT_RX_ENABLE(handle->uart->UARTx);
      uart_nvic_enable(handle);
      void uart_driver_start_receive(UART_UserTypeDef_t *handle,
      uint8_t *p_data,
      uint16_t max_byte_num,
      void (*UsrRxCpltCallback)(struct __UART_HandleTypeDef *huart))
      handle->uart->RxCpltCallback = UsrRxCpltCallback;
      uart_receive_IT(handle->uart, p_data, max_byte_num);
      while (huart->UARTx->LSR.LSR_BIT.DR)
      huart->p_RxData[huart->u32_RxCount++] = huart->UARTx->DATA_DLL.DATA;
      现在是反复进入那个超时的case里,寄存器的状态在上面贴出来了
      发布在 FR303x
      zxy
    • RE: 堆栈溢出
      @zr 我去改这个东西是因为我在连接成功后就一直周期的获取RSSI,然后在这期间只要主机向我发起配对就会进入这个地方,这种情况应该改哪个大小呢
      发布在 FR303x
      zxy
    • 串口中断异常,一直进中断
      0_1762773328356_bc9eeeea-537b-412a-a420-3db699699dfe-1762772913109_ecebe42d0ab0411da39d25434ea28720.png
      0_1762773353102_b4aea36b-8478-4057-a047-a75e27fc4f5a-1762772961922_7e13f27c951f4246a8a6cb53bb02aa25.png
      FCR_IID寄存器的结果是0xCC,有超时中断,但是LSR.LSR.BIT.DR是0,导致进不去读数据的while,但是一直在进中断,能不能帮忙看一下要怎么解决
      发布在 FR303x
      zxy
    • RE: 堆栈溢出
      我想稍微增大一点堆栈大小和分给freeRTOS的空间,但是报错了,我应该怎么调整呢?
      发布在 FR303x
      zxy
    • RE: 堆栈溢出
      @zr 它会影响别的内存起始地址或长度吗,如果不会可以直接调到最大吗
      发布在 FR303x
      zxy
