    2. stallone
    S
    • 继续与 stallone 聊天
    • 开始与 stallone 的新会话
    stallone
    @stallone
    stallone 关注
    stallone 发布的帖子
    • RE: 需要提供OTA更新的示例代码 / Example needed for OTA update
      简单来说……假设我想在 https://gitee.com/freqchip/FR801xH-SDK/blob/master/examples/none_evm/ble_simple_peripheral/code/proj_main.c 中添加 OTA 更新功能
      添加这几行就够了吗?!
      Let's keep it simple... let's say I want to add OTA update feature to https://gitee.com/freqchip/FR801xH-SDK/blob/master/examples/none_evm/ble_simple_peripheral/code/proj_main.c
      Is enough to add these lines?!
      S
      stallone
      Thanks! I tried but I get this error:
      谢谢!我试过了,但出现以下错误:
      PS C:\Users\stallone\Desktop\ZIKR\FR801xH-SDK\examples\none_evm\ble_AT\gcc> make
      mkdir build
      cd build && mkdir AT_prj
      Compiling: ../code/proj_main.c
      Compiling: ../code/at_gap_event.c
      ../code/at_gap_event.c:25:17: error: static declaration of 'current_con_interval' follows non-static declaration
      static uint16_t current_con_interval = LINK_INTERVAL_MIN;
      In file included from ../code/at_gap_event.c:15:0:
      ../code/at_gap_event.h:18:17: note: previous declaration of 'current_con_interval' was here
      extern uint16_t current_con_interval;
      ../code/at_gap_event.c: In function 'at_cb_slave_connected':
      ../code/at_gap_event.c:298:57: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
      os_timer_init( &update_param_timer,param_timer_func,(void *)(param->conidx));
      make: *** [../../../../components/toolchain/gcc/Makefile.common:147: build/AT_prj/at_gap_event.c.o] Error 1
      S
      stallone
      @felix-yang unfortunately that example does not contain the "gcc" directory and proper MakeFile
      @felix-yang 不幸的是,该示例不包含“gcc”目录和正确的 MakeFile
      S
      stallone
    • RE: FR8018使用rtos例程时,应该如何正确添加ota服务?
      @zhangmm 您好,可以再上传一下演示版本吗?
      我想尝试一下,了解如何使用 OTA 更新 🙂
      非常感谢!
      S
      stallone
    • 需要提供OTA更新的示例代码 / Example needed for OTA update
      您好,
      能否在您的SDK[1]中添加一个基于GCC可编译运行的OTA更新示例?这将帮助我学习如何添加OTA功能。
      [1] https://gitee.com/freqchip/FR801xH-SDK/tree/master/examples/none_evm
      目前根据中文文档的说明,我了解到需要在项目初始化时调用ota_gatt_add_service()来添加OTA服务。在该手册中...
      在其他文档中我还看到这张经过翻译的示意图...
      ----- ENGLISH TRANSLATION BELOW FOR REFERENCE ----
      Hi,
      Can you please add a working and buildable example with gcc on your SDK [1] that will teach me how to add the OTA update?
      So far looking at your documentation in Chinese I see I need to use call ota_gatt_add_service() to add the OTA service when the project is initialized. In this manual...
      In some other documents I also see this graph which i translated...
      S
      stallone
    • RE: FR8016HA SDK & Keil 5.42 Setup Guide
      Whatever... I solved using directly GCC to build the app...
      So far, due the lack of proper English documentation and tons of different manual files in Chinese... this MCU is not the best I used so far...
      S
      stallone
    • FR8016HA SDK & Keil 5.42 Setup Guide
      Hi there,
      Anyone has some notes or tutorials (in English) on how to properly setup Keil 5.42 and the FR8016HA SDK?
      This MCU may be cool... but the lack of English documentation and proper setup in structions is very time consuming... 🥲🥲🥲
      S
      stallone
