<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[initial_static_memory的参数]]></title><description><![CDATA[<p>版主我在多连接的时候，看到例子里面有个initial_static_memory， 这里的内存分配是怎么计算的？</p>
<ul>
<li>default setting is      initial_static_memory(9, 2, 6, 8, 251, 8, 251, 254, 0x800);  这个我测试下来程序能正常跑起来。改成如下的参数就是跑不起来<br />
initial_static_memory(16, 2, 14, 16, 120, 16, 120, 100, 0x800);<br />
我想多增加一点连接。按理 rx_buf_num* rx_buf_size + tx_buf_num* tx_buf_size不是更小了，怎么反而跑不起来？跟连接数相关么？具体怎么计算的，或者哪里设置要改一下才行？<br />
void initial_static_memory(uint8_t act_num,<br />
uint8_t adv_act_num,<br />
uint8_t con_num,<br />
uint8_t rx_buf_num,<br />
uint16_t rx_buf_size,<br />
uint8_t tx_buf_num,<br />
uint16_t tx_buf_size,<br />
uint16_t max_adv_size,<br />
uint16_t stack_size_)</li>
</ul>
]]></description><link>http://www.freqchip.net:4567/topic/1831/initial_static_memory的参数</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 03:57:31 GMT</lastBuildDate><atom:link href="http://www.freqchip.net:4567/topic/1831.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Jun 2026 09:36:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to initial_static_memory的参数 on Invalid Date]]></title><description><![CDATA[<p>版主我在多连接的时候，看到例子里面有个initial_static_memory， 这里的内存分配是怎么计算的？</p>
<ul>
</ul>
]]></description><link>http://www.freqchip.net:4567/post/4474</link><guid isPermaLink="true">http://www.freqchip.net:4567/post/4474</guid><dc:creator><![CDATA[fu]]></dc:creator><pubDate>Invalid Date</pubDate></item><item><title><![CDATA[Reply to initial_static_memory的参数 on Invalid Date]]></title><description><![CDATA[<p><a class="plugin-mentions-user plugin-mentions-a" href="http://www.freqchip.net:4567/uid/1889">@fu</a> 【有道云笔记】FR801xH 栈空间设置<br />
<a href="https://share.note.youdao.com/s/SXMbqxBd" rel="nofollow">https://share.note.youdao.com/s/SXMbqxBd</a><br />
参考下</p>
]]></description><link>http://www.freqchip.net:4567/post/4484</link><guid isPermaLink="true">http://www.freqchip.net:4567/post/4484</guid><dc:creator><![CDATA[ZR]]></dc:creator><pubDate>Invalid Date</pubDate></item></channel></rss>
